tested Interface for Supervision (from Värmepump Diplomat)
Gäst
It seems that it is the same Cabel/interface as they use to the heat-Pump Diplomat..
That interface + Thermia supervision software..
Cost = under 1000:- Sek.
Some one know were to find the Software? my copy is gone to heaven! (my HD died on me)
Gäst
The interface
The "interface" should not be hard to build yourself. I assume it is RS232 to RS485 or something like that. Anyone have any info?
Thermia Biomatic 20+, 3,5 ton bulkförråd, Acaso Automix 20 shuntautomatik.
Gäst
Gäst
per pellet
- Fröträd
Unfortunately:
Your message
Subject: "Interface 518"
could not be delivered to some or all of the intended recipients.
User<roland.lund@thermiapellets.se> - (550 5.1.1 User unknown)
Biomatic 20+, 800 liter veckoförråd, Thermomatic Combi shuntstyrning.
per pellet
- Fröträd
And further:
The following recipient(s) could not be reached:
info@thermiapellets.se on 2006-05-09 09:54
The e-mail account does not exist at the organization this message was sent to.
Check the e-mail address, or contact the recipient directly to find out the correct address.
<web-is-s104.web2000.activeisp.com #5.1.1 smtp;550 5.1.1 <info@thermiapellets.se> is not a valid mailbox>
Gäst
