Bequem burner bowl - New design...
Gäst
Inlägg av Gäst »
Mounted today. Tell you more after some hours in use...
Per-Erik
Inlägg av Per-Erik »
Did you make it your self or did Thermia make one for you.?
What shuld be the advantage whit that Bowl now? it can keep more pellets = more heat...?
Gäst
Inlägg av Gäst »
It comes from thermia.fi as a spare part to remove the old one (why is described in the forum)
Advantage? Maybe no more overheated and then broken parts...
The secondary Air ring can be removed.
One thing i saw is very less flying ash.
We´ll see.
Gäst
Inlägg av Gäst »
So, here is my review of the new burner bowl:
The bowl is wider and longer. The pellets burn much better because of less air-speed.
There are no more holes, but slots instead. The advantage is, that no ash or sintered material can block this air- outlets anymore.
Because there is no more secondary air-ring over the burner-bowl, it cleans itself much better from unburned pellets, ash and sinter.
______________________________________________________
Below the old type of burner bowl and the secondary air-ring upon it.
The fluegas temp rised about 20 degrees up to 170. I think the flames have more time to burn out now. Before, there was a concentrated gas-stream out of the secondary air-ring. Now the flames burn longer and quieter.
The amount of ash in the horizontal fluegas-channels is reduced very much.
It seems, my boiler is working more efficient now.
Secondary air now is blown right over the glowing pellets through the pipe where the secondary air-ring was mounted.
It is now similar to the ecotec burners, which also have a pipe with secondary air facing to the burner bowl.
All in all: I am very satisfied with the changes thermia made[/img]
joa
Inlägg av joa »
Is this now standard on all new factory produced burners?
I guess there are quite a few of the old version in stock and out at their retailers :(
I'm about to buy one in the coming weeks.
//Jocke
Per-Erik
joa skrev:Is this now standard on all new factory produced burners?
//Jocke
Noo.. I think Libi has the 50kw burner from thermia.. :)
Libi has a big house or "Castle" :lol: :wink:
300 Kvm if i am not wrong..
Gäst
Inlägg av Gäst »
"Your Majesty, King Libi , pellets are served !"sounds not bad 8)
In this brochure http://www.ariterm.fi/pdf/BeQuem_20_ja_50.pdf you can see the actual burners (with the actual bowls).
Watch the kind of slots inside the bowl, if you buy your burner from your dealer.
Attention: Lots of trange letters (ääää iiii ööö) in the text :twisted:
stefanstrandberg
Inlägg av stefanstrandberg »
Hi Libi,
I have the same burner as You, the Bequem 50 kw burner from Thermia. Installed in october 2005. I got the old type of burner bowl, what kind of problems acyually did occur with the old version?
Stefan
Thermia Bequem 50 / Termax 40 Kw +2*300l. acc.tank. & Casaflex Duo DN25 tot. 100 meter.
Gäst
Inlägg av Gäst »
Hi Stefan,
look here :shock:
Ariterm in Saarijärvi sent me the new part on warranty...
stefanstrandberg
Hi Libi,
Oups.... That picture(s) explains quite much. Thanks. I have not yet found such pieces in my ashbox. So far so good....
Stefan
