i wonder if Ariterm plans to include the function of cleaning the burner bowl using the build in fan.
I´ve seen some other (horizontal) burners, that switch the internal fan to full speed in an adjustable intervall. This cleans the burners inside very well from ash and dust.
What do you think?
Automatic cleaning of burnerbowl?
Ideal Standard 1965
Bequem 50
12 t Storage
9m screw
450 m2
Bequem 50
12 t Storage
9m screw
450 m2
Re: Automatic cleaning of burnerbowl?
It's already implemented!
If you listen to the fan you can hear that it increases with regular intervals. (Don't know the time in between, probably 10-30min)
Hej Zeylon,
i was watching my burner several times. I did not recognize a change in the fan-speed. For me it would not make sense if the fan blows stronger while the burner is running - in my opinion it would just blow out the burning pellets.
It would be usefull to blow out the ash after burning. When burners is off for i.e. 1 hour or so....
Ideal Standard 1965
Bequem 50
12 t Storage
9m screw
450 m2
Bequem 50
12 t Storage
9m screw
450 m2
