RRDbuddy
zorro
Re: RRDbuddy
Inlägg av zorro »
parameter fliken uppdateras inte heller men graferna funkar???
Re: RRDbuddy
Graferna går inte via websocket, det är gammaldags polling. Hur var det med status 101 i developer tools/network? Nåt nytt error om du startar med ./debugweb?
zorro
Re: RRDbuddy
Inlägg av zorro »
Så här ser det ut
uppdaterings fel.jpg (164.53 KiB) Visad 4256 gånger
zorro
Re: RRDbuddy
Inlägg av zorro »
Detta vad va jag fick av debugen
pi@rrdbuddypi ~/rrdbuddy-master/src $ sudo ./debugweb.sh
[30/Jul/2015:17:35:32] ENGINE Bus STARTING
[30/Jul/2015:17:35:32] ENGINE Starting WebSocket processing
[30/Jul/2015:17:35:32] ENGINE Started monitor thread '_TimeoutMonitor'.
[30/Jul/2015:17:35:32] ENGINE PID 13983 written to '/tmp/rrdbuddyweb.pid'.
[30/Jul/2015:17:35:32] ENGINE Started monitor thread 'Autoreloader'.
[30/Jul/2015:17:35:32] ENGINE Serving on 0.0.0.0:8082
[30/Jul/2015:17:35:32] ENGINE Started as uid: 'root' gid: 'root'
[30/Jul/2015:17:35:32] ENGINE Running as uid: 'rrdbuddyweb' gid: 'nogroup'
Exception in thread Thread-1:
Traceback (most recent call last):
File "/usr/lib/python2.7/threading.py", line 552, in __bootstrap_inner
self.run()
File "/usr/local/lib/python2.7/dist-packages/ws4py/manager.py", line 303, in r un
for fd in polled:
File "/usr/local/lib/python2.7/dist-packages/ws4py/manager.py", line 138, in p oll
events = self.poller.poll(timeout=self.timeout)
IOError: [Errno 4] Interrupted system call
[30/Jul/2015:17:35:32] ENGINE umask old: 022, new: 033
[30/Jul/2015:17:35:32] ENGINE Bus STARTED
192.168.100.37 - - [30/Jul/2015:17:35:34] "GET /websocket/ws/?parameters=sugledn ing,ute_temp,hetgas,vb_ut,vb_in,vatskeledning,efter_exventil&events=yes HTTP/1.1 " 101 - "" "Mozilla/5.0 (Windows NT 6.1; WOW64; Trident/7.0; rv:11.0) like Gecko "
192.168.100.37 - - [30/Jul/2015:17:35:35] "GET /websocket/ws/?parameters=sugledn ing,ute_temp,hetgas,vb_ut,vb_in,vatskeledning,efter_exventil&events=yes HTTP/1.1 " 101 - "" "Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/44.0.2403.107 Safari/537.36"
zorro
Re: RRDbuddy
Inlägg av zorro »
Har testa detta nu
1 startat om RPI =uppdatering värden fungerar ej
2 sudo service rrdbuddysrv restart =uppdatering värden fungerar ej
3 sudo service rrdbuddyweb restart =uppdatering värden fungerar ej
4 sudo service rrdbuddyweb restart efter detta sudo service rrdbuddysrv restart =uppdatering fungerar
Re: RRDbuddy
Inget konstigt i den errorloggen, det där samma felet får jag också då jag startar i debugläge (minns inte exakt nu vad det var frågan om), men det fungerar ändå.
Svar till nyaste inlägget. För säkerhets skull, du kör alltså fortfarande med develop versionen?
Om jag fattar rätt:
Master: allt fungerar med sudo service rrdbuddyweb restart, efter omstart av rpi
Develop: allt fungerar med sudo service rrdbuddysrv restart, efter omstart av rpi
zorro
Re: RRDbuddy
Inlägg av zorro »
Japp kör develop
måste starta om både web+srv enl.
Re: RRDbuddy
Ok, undersöker saken vidare. Tack för debughjälpen så långt.
zorro
Re: RRDbuddy
Inlägg av zorro »
Inga problem
det är synd att man är så dålig själv på programmering så man kan inte tillföra så mycket mer än och testa :mrgreen: :mrgreen:
Re: RRDbuddy
Testade en ny grej i develop, om du orkar kolla ifall det hjälper.
zorro
Re: RRDbuddy
Inlägg av zorro »
ehö fattar inte riktig
ska jag ladda ner denna igen https://github.com/motoz/rrdbuddy/archive/develop.zip :?: :?:
och installera
Re: RRDbuddy
Javisst, ny versiom igen...
Sent using Siilihai web forum reader
zorro
Re: RRDbuddy
Inlägg av zorro »
ok absolut orken finns hur mycket som helst
jag testar och laddar ner
Återkommer med resultatet i morron EM ska jobba natt nu
Tack för all hjälp :mrgreen: :mrgreen:
bosse123
Re: RRDbuddy
Inlägg av bosse123 »
Vet att även i min gamla PellMon version behöver man manuellt starta pellmonweb och srv ibland när man har startat om ubuntuservern.
provade just nu med detta resultatet efter en "reboot":
root@server2:~# service pellmonsrv status
* pellmonsrv is not running
root@server2:~# service pellmonweb status
* pellmonweb is not running
root@server2:~# service pellmonsrv start
* Starting pellmonsrv... process already running.
[fail]
root@server2:~# ps -ax | grep pellmon
Warning: bad ps syntax, perhaps a bogus '-'? See http://procps.sf.net/faq.html
1912 ? Sl 0:00 /usr/bin/python /usr/local/bin/pellmonsrv.py start -- PIDFILE=/var/run/pellmonsrv/pellmonsrv.py.pid --USER=pellmonsrv --GROUP=nogroup --CONFIG=/etc/pellmon/pellmon.conf --DBUS=SYSTEM --PLUGINDIR=/usr/local/lib/Pell monsrv/plugins
2013 ? Sl 0:00 /usr/bin/python /usr/local/bin/pellmonweb.py -D --PID FILE /var/run/pellmonweb/pellmonweb.py.pid --USER=pellmonweb --GROUP=nogroup --C ONFIG=/etc/pellmon/pellmon.conf --DBUS=SYSTEM
2667 pts/0 S+ 0:00 grep --color=auto pellmon
root@server2:~# kill -9 1912
* Starting pellmonsrv... pidfile /var/run/pellmonsrv/pellmonsrv.py.pid already exist. Daemon already runn ing?
[fail]
startade på nytt om ubuntuservern då blev utgången denna:
* Starting pellmonsrv... [ OK ]
root@server2:~# service pellmonweb start
* Starting pellmonweb... [ OK ]
inget större problem egentligen, ytterst sällan jag startar om servern, de flesta applikationer går ju att starta om i ubuntu separat till skillnad mot Bill Gates miljöer...
Viking bio 20 i en vedolux 40, ackumulatortankar och 15m2 solfångare.
Re: RRDbuddy
Bosse, kan du upprepa problemet med en modern omoddad version av PellMon så gör gärna en buggrapport eller inlägg i pellmontråden med info om vilken ubuntuversion du använder. Jag skulle klassa den buggen som katastrofal, men hur som helst så är det ett helt annat problem i ett annat program.
