My P21 (2006, chip 2V70) is in its 2. winter cycle.
The red LED stops I saw, were basically caused by the flame-light sensor, which is rapidly varying its electrical resistance. So, a flickering fire, a bunch of new pellets in the wrong place, might cause a quick reaction. The burner then sets the red LED and goes into a fault state.
I improved this behaviour by installing a small 1 uF foil capacitor in parallel to the flame sensor at the connection on the control-board. This significantly slows down the reaction and gives the sensor a chance to recover. Since then, its fine.
I still experience problems with double-starts.
Actually, the burner runs in long sequences, approx 90 minutes, to heat up the buffer.
Randomly, it goes into exit firing, shuts off, and starts right away again, with the full startup cycle. The german importer assumed it to be a cleaning cycle, but I don't think so.
I already assumed a temperature sensor problem, but this does not appear to be true.
Any ideas ?
Any experience how many years does the heavy burner tube withstand
the heat and needs to be replaced ?
