bequem´s calculating of pellets left
Gäst
Inlägg av Gäst »
i wonder about how my bequem50 burner calculates the estimated days left with my actual amount of pellets in the storage.
i have 3.8 tons pellets left.
the average consumption(forbrukking) is 5,6/
the display says: 616d left
my question is:
average forbrukking: 5,6 kg/hour (is this right)?
3800kg pellets / 5.6 kg/h = 678 hours running time left
678 hours / 24 h/day = 28,25 days left
why does the display say : 616 d left :?: :?:
wertok
Inlägg av wertok »
I think you´ve got the figures wrong.
The average consumption(forbrukking) is 5,6/day not hour. But 5,6 a day is very low if it´s cold outside so I think that you have the matningsfaktor wrong. My matningsfaktor is 14,4 kg/h that means that when I now have a average consumption of 27 kg/day that the extern skruv is on appr. 2 hours/day (2*14,4=28,8kg).
Då: 30 000:-/år med olja :-(
Thermia Biomatic 20+
4 kg/m² & månad
Huset byggt 1947
Gäst
Inlägg av Gäst »
my actual matningsfaktor is about 11,4.
in the usermanual is nothing written if the cunsumption is per day or per hour.
i am sure that the screw runs more than 1/2 an hour per day!
i will check the matning/hour now.
wertok
Inlägg av wertok »
If you consume 6 kg every hour it would cost 32€ each day in swedish price of pellets.
4 kg/m² & månad
Huset byggt 1947
Gäst
Inlägg av Gäst »
yes that´s right.
my oil-burner drunk 4,8l/hour. If it was on 12 hours a day = 57 l/dayx 0.65€= 37 € oil
that´s why i changed to pellets.
we have a small hotel with 500m2 to heat.
Gäst
Inlägg av Gäst »
so, i´ve checked the matning/15 min.
3,7kg/15 min x 4= 14.8 kg/h
the forbrukking got worse :twisted:
i deleted the counter of the screw-runtime and keep on watching.
wertok
Inlägg av wertok »
But I still mean that the consumption/förbrukning showed is per day not per hour!
4 kg/m² & månad
Huset byggt 1947
Gäst
Inlägg av Gäst »
then it is a cheap heating-system indeed.
hmmm
. i should check the running time of the screw per day. i will connect a electric mechanical timer, which only runs when the screw runs too.
pitch
Inlägg av pitch »
libi skrev: we have a small hotel with 500m2 to heat.
Nice!
A pellet heated hotel is just where I like to stay.
Where are you located?
Maybe I'll drop by just to check your Thermia burner :wink:
/Pitch
Gäst
Inlägg av Gäst »
:roll:
wertok
Inlägg av wertok »
But a consumption of 7 kg/day to heat 500 m2 is not either realistic. We have 120 m2 and consumes 25-30 kg/day and the outside temperature here now is 0 - +5 degrees.
Something is wrong with your figures but I can´t find it...
My Bequeem calculates everything exactly.
4 kg/m² & månad
Huset byggt 1947
pitch
Inlägg av pitch »
Is that building only 500 m²?
It seems more like the double...and it's very nice...
I´ll probably get by you some time...
/Pitch
Gäst
Inlägg av Gäst »
just read in the (very poor) german translation of the swedish usermanual:
the shown pellet-usage is the average usage of the last 8 days.
almost cannot believe that that is true...
imagine: 8 kg/day = 4 l oil a day = 40Kw a day = 1.6 kW/h
Gäst
Inlägg av Gäst »
correct
Gäst
Inlägg av Gäst »
after 24h of measuring i have the following data:
boiler temp. 62°
outside average temp. -5°
in 24 hours the skrew runs 9 hours.
14.8kg/h x 9 = 133 kg /day
133 kg/day x 5 kw (Pellets) = 665 kW in 24 h
665/24= 27.7 kw/h
