Biomatic Burner modification "duserhjul"
jeffrey
Inlägg av jeffrey »
hi
i have made a little modification on my thermia biomatic 20 pellet bruner , i had always the problem that the upper "duserhjul" was blocking because the teeth of the upper pinion were using.
just look at the pictures:
this works now since some months absolutly perfect , there is no difference on the burning quality . if you have any questions just ask me/ sorry that i dont speak swedish.
jeff
Becker
Inlägg av Becker »
Hi Jeff!
Nice! :)
Is it Your own design?? or have You bought the things from Ariterm?
jeffrey
Inlägg av jeffrey »
hi becker
yes this is my own design, the chain and the pinions you can buy very cheap in any hardware store.
jeff
Brynäs
Inlägg av Brynäs »
Hallo Jeff!
Very good!
If i have some problems whit mine burner I will call you and you can make the modifications fo a small feed of course :lol:
1 1/2 plan 118m2+68m2 källare
jeffrey
Inlägg av jeffrey »
Works still perfect :D , any probems . I can just recommand it :thumright:
